#1 | |
Liked 784 Times in 196 Posts
If you look at NHRA's sheets, they list the same intake manifold for the 267 with a DualJet and the 305 with the 2GC; is that possible? (I am not familiar with DualJets, other than they look like the front of a Qjet.) Also, is either of the 79 intake manifolds (14007372 & 14007374) aluminum? The 78 alt intake 346260 is also used on the 76 and 77 305s, and the 75 and 76 350 2bbl. (Probably the 74 also; the tech sheet says 346266 but that could be a typo.) Agreed. |
Liked 7,925 Times in 1,760 Posts
No. The dual-jet and the 2GC have a different bolt pattern. I've had a 79 Caprice and a 79 Camaro, 305s both that had dual-jets on them. I wouldn't doubt that it has something to do with where the cars were built and what plant supplied the engines.
I did a bit of research last night and found that the two intake manifolds listed on the 79 tech sheet are both for DualJet. In fact, I physically inspected a 14007372 number which is cast iron. I'm going to chase down the carb numbers next. Billy, I think you are probably right about supply and model usage; maybe it has to do with timing in the production year, too. My Monza was ordered in September 1978 and delivered in October.
Liked 169 Times in 53 Posts
I've been running the 82 267 Monte Carlo combo for a year now and I have to say the intake manifold on this car has to be the world's heaviest for a small block chevy. Love that dual-jet too. '
Bill Bogues 4696 STK |
Liked 411 Times in 114 Posts
Been looking at some of these U/SA combos such as the late 70's Camaro with the 305-2V and the 80's combos with the 267-2V . At 180 HP vs. 150 for the 267 is it worth carrying the extra 600 lbs. with the 305 ? Which is the better combination and what other chevy combos may be the way to go for U ?
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC Last edited by joe huestis; 02-05-2014 at 10:03 PM. |
Bill, there is an aluminium intake available. I just don't remember which one it is.
Liked 9 Times in 9 Posts
How does one go about fixing this? The tech sheet calls for what looks like the 2GC though the intake is not?. I could swap grilles and make a 77 ( have to change header panel too) or 78 (run in T) but the 79 is a favorable U. Looking at a 79 Caprice 2dr, the funky sloped back window version.
Joe Toller Lewistown, MT |
Make it a 77.
77 is a big change with the bumpers. What's wrong about the '78? Run it as an LT and it is still in U. Much easier change.
![]() Last edited by Dwight Southerland; 12-30-2018 at 09:42 AM. |
Liked 485 Times in 160 Posts
Are you discussing Camaro or Caprice ?
