Old 08-17-2007, 03:05 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: Schubeck Lifter Update
FYI, here in the USA we call it "exhibition of speed" and it's a license revoking 8 point penalty, same as "street racing". Sometimes involves jail time and confiscating your vehicle. Permanently. Wouldn't matter if you had the only car on the road for miles. But maybe it's different in Canada? Next time the Royal Canadian Mounted Police drop by your shop ask them if it's OK. NHRA was formed to combat this type of activity. What your doing takes away from the credibility of the sport. We like to "drag race", you like to "street race". You're on the street and you're making acceleration trials. That's "street racing".
No, I entirely disagree with your statement "Simply, if acting responsibly, it's a SAFE environment to tune the car". Most of us did the same when we were 16 years old. But now we are adults. Or at least we're supposed to act like it.
To LNorton,
I would be upset if the lifters were a problem also. But I'm not convinced the problem is with the lifter. These ceramic inserts are basically glued on. I'm not sure if anybody has tested a set for long term durability. Just as stated by Fishlips, if the valves are net set correctly or become loose, it will pound on the valvetrain and you can loose the ceramic insert. The pictures seem to indicate that may be the case. Think about it, some of these stock racers adjust their valves at least every race, sometimes more. On my Stocker I found the ONLY way to keep the lash in control was to adjust all 16 every other run! One race with driving in the pits and racing might accumulate 10-15 minutes of run time? Here we have 2.5 hours on the street. That's the equivalent of 10+ races, timewise. I would have adjusted the valves 15-20 times in this period.
Long before Schubecks it has been known the stock eliminator cam and valvtrain are not suitable for street use. Profiles are just too harsh. My opinion is a rocker got loose and pounded the lifter to death.
Jeff Lee 7494 D/S '70 AMX
Old 08-17-2007, 11:31 AM   #2
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Yes Fishlips, I agree.. lifter striking the cam is the most likely cause of losing the puck.
Have Crane "nitro carb" 1.7 BBC rockers and Comp .080" wall 3/8" pushrods ( about an inch shorter than BBC ). I previously ran this engine for two years, with these lifters, on a cam with the same lobes, but less piston-to-valve clearance. NEVER had any problem with the valve train ( althougth it DID break an ARP rod bolt on no.1 cyl ).
The rocker puncturing was random... this bank, that cylinder... other bank... blah blah blah ( happened 4 times ). Never had a rocker problem on the valve that broke the lifter. Been running mechanical cams for 30+ years, have set a LOT of valves, know how to do it ( ask the guys at Lee Brothers Automotive in Red Deer, how much of a fanatic I am about lash ). And yes, during the time, I did 3 hot adjustments.
Ya' know, Jeff... when I was young, late teens to late 20's, I had occasion to be at a few different drag strips. Sometimes just to watch, a few times with my own car, bracket racing / just trying to have fun.
What became evident all too often, and was quite consistent, was the people. In the pits, in areas where the "stickered cars" were... the real racers, for the most part, was a gathering of rather unpleasant individuals. I'll leave it at that. But suffice it to say, it was the attitude of this "type" that kept me away from a drag strip for over 10 years. Just wasn't that much fun.
Now, I'm trying to be part of that ?
Anyhow, I'll tell you what... I'll go down to my local rcmp station here, and talk to one of the guys/girls, and see what their attitude is.
However, despite the fact that I am clearly offended by your attitude, I will take the "big picture" intent of your comment respectfully, and likely adjust my habits somewhat.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 08-17-2007, 01:15 PM   #3
Bob
Aubrey,
Don't worry about Jeff''s comments. As usual he is wrong on most of his points.
First off, he said "FYI, here in the USA we call it "exhibition of speed" and it's a license revoking 8 point penalty, same as "street racing". Sometimes involves jail time and confiscating your vehicle. Permanently."
Well maybe in in Arizona, but not in all states. In fact many midwestern states do no use the point system.
Second, he said "What your doing takes away from the credibility of the sport. We like to "drag race", you like to "street race". When he uses the word "we" he is trying to portray that he is speaking on all NHRA members behalf. Trust me he is NOT. Very few share his views.
Third, he said,"You're on the street and you're making acceleration trials. That's "street racing". Ask him how that is ONE BIT DIFFERENT than when he is late to show a house and he speeds down the freeway. Or how it is ONE BIT DIFFERENT than when he leaves a stop light and floors it to get out in front of all the traffic behind him.
Bob is offline   Reply With Quote
Old 08-18-2007, 12:42 PM   #4
Fishlips
Hey Jeff,
I argee with Aubrey but am a little less polite, PISS OFF!
What gives you the right to tell someone in another country what to do or impose your view of responsibility on them?
I'm sure your Halo has some tarnish on it too!
Bryan Broaddus
Fishlips is offline   Reply With Quote
