Old 02-15-2013, 12:13 PM   #1
bert powell
Liked 34 Times in 12 Posts
Default Re: New for 2014
Originally Posted by Pedigo Perf View Post
I suppose another way NHRA could address this issue is to DQ or even fine any racer that has parts fall off his car during an event. Which would you prefer?
Header bolts are notorious for vibrating loose for obvious reasons. My collectors are welded, but when bolts are used they should be used with locking type nuts. Most aren't.
That is exactly what NHRA should do instead of forcing every racer to spend money because some do not check there stuff or use the correct hardware. I am under my car after 40 runs checking for loose bolts, etc. I have replaced grade 5 collector bolts many times because the threads look bad from overtightening. I switched to grade 8 bolts, lockwashers and crimped locknuts.
bert powell is offline   Reply With Quote
