#1 | |
Liked 184 Times in 113 Posts
Got a good jump on a 9 second Nova that blew past me in the traps at Cecil. It disgorged its exhaust system in front of my car. Was lucky enough to dodge the pieces at 100 mph... FWIW not the first time had to avoid crap falling off a fast car. D |
#2 | |
Maybe it does ..with these guys..You never know. http://www.lokar.com/product-pgs/dra...g.html?t=34740 Nice! Classy!
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 02-14-2013 at 08:09 PM. |
Liked 29 Times in 14 Posts
Seems like it would make good sense to specify the "tether" does not permit the collector from becoming separated from the primary tubes.
As stated earlier, having a collector bouncing under car travelling down track is an additional concern. It would also make sense to contact some of the header builders to establish a best practice for safely mounting collectors to headers. |
So, if I'm reading this correctly, a car with removable collectors and collector extensions would need two safety tethers per side, correct?
How about a car with an X-pipe with multiple pieces? Just curious.......
SS/MA 5017 |
If the collector is full welded to the primary pipes would it still be considered removable ? I dont think so and if that is the case ,do you need these tethers ?
This does not pertain to all headers as they have to be disassembled to remove from chassis. |
Liked 275 Times in 76 Posts
I have had one tech inspector look under my car, and I was impressed with him and commented that he was the first to do so. I think it could have been that I was an racing in a different division. But most of our cars are not easily accessible to see what is under the car. Especially the headers and tabs.
Sean
Where these are really needed are on funny car bodies. Sooner or later one of those is going to land in the stands. If they have a tether they aren't working very well.
#8 | |
My own experience: I had one complete collector come off at the hit of the throttle on the starting line. It went under my right rear slick and was shot out the rear. Fortunately it didn't puncture the tire or hit the starting line crew in the process. NOW every tube has a tab that is bolted together with lock washers and double nuts. All is well since then. |
