#1 | |
Liked 32 Times in 9 Posts
Liked 70 Times in 22 Posts
Had a PM from a regular poster on here and he hit on a point not yet mentioned. Power strikes on the crank. As Jeff pointed out the drop is less on the 3-4 shift than the 2-3 shift. So the initial rpm after the gear change is higher resulting in more power strikes for the same time period and at a higher HP (RPM)level so more force is applied at the 3-4 shift than any other shift.
Jeff When is the "very near furure"? Don't think I'll be out this year in my car. I went against the trend and made a couple realtors happy. Bought a house on 4 acres with a 3000' shop. Still own the other house and equiping the shop so not much spending on the Cuda. Putting the old house on the market in a couple weeks. Will take a beating but got a deal on the new one so we don't care. You selling anything out there?
Stewart Way 2424 SS |
Yes, I`ve had several McLeod Soft Loks rebuilt by both McLeod as well as Tim Hyatt, and each time new heat shields were installed on the flywheels and pressure rings. Usually by the time the clutch needs a rebuild, the heat shields are getting blue hot spots, irregular surfaces, and the outer edges that don`t see disc contact are curling up.I would have to think that any money saved by grinding the old heat shields would be offset by a very rapid re-occurance of warpage. New heat shields are a must.
