Old 09-08-2011, 10:56 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Stocker block SBC
I am starting at the bottom and working up a plan for the block and ran across a few questions.
In the rule book it states that the engine must be "same year" as car used. Is this to say you have to run a 1975 casting in a 1975 car? And do the tech guys really check casting dates?
Is it better to run an aftermarket (approved) Dart or World Products block?
My intentions were to take an old 4 bolt main block I have here and put 8 sleeves in it have it align-bored, and squared/decked. I was tossing around the idea of bronze lifter guides as well, are the worth the effort/cost as long as I am having the remainder of the block machined?
The block I have is not the "same year" as car used and now that I am looking at these aftermarket blocks I am wondering if the additional weight in the casting is worth it to have a more rigid block.
Thanks in advance.
Chad
Chad E532 is online now   Reply With Quote
Old 09-08-2011, 10:57 PM   #2
Chad Rhodes
Default Re: Stocker block SBC
Thanks in advance.
Chad
if you are gonna spend that kind of money, get the dart
Chad Rhodes 2113 I/SA
Old 09-08-2011, 11:26 PM   #3
Liked 1,876 Times in 422 Posts
Yep, save yourself time and money, go Dart, and don't look back. By the time you do what you want to a 30 year old block that wasn't great to begin with, you can buy a near finished Dart that will last years. And the Dart will make HP. Find a Dart dealer and get them to order it for you like you want it.
Old 09-10-2011, 12:04 AM   #4
Geerhead55
Liked 5 Times in 5 Posts
Red face Re: Stocker block SBC
Alan,,,assuming there are no stupid questions,,I'm going to fire this one off.
When it comes to Dart blocks for a small block Chevy, I know there is the SHP block
and the "Lil M" block. Are either of these blocks acceptable for Stock by NHRA, or is there another Dart block that is approved that I'm unaware of? I've also heard the SHP block takes a different, longer lifter as compared to the others, correct?
Thanks for your input as always.
Danny Durham
Old 09-10-2011, 12:16 AM   #5
Jeff Lee
Jeff Lee's Avatar
To answer the basic question, yes...you can run any year block as long as it's the same family. The original size of the block (262, 265, 283, 327, 350) is of no concern to tech. Just bore / stroke and technically lifter bore diameter and deck height (which is primarily dictated by the NHRA spec stroke, rod length and compression height and deck clearance).
That is why you see 454 blocks sleeved down to a 396 bore. It's all good.
And while I have never raced a class car with an aftermarket block, I would if one were available. There are MANY advantages as mentioned below. The cost is negligible compared to what you get.
Jeff Lee 7494 D/S '70 AMX
Old 09-10-2011, 01:12 AM   #6
Danny Durham
Danny, the Little M Sportsman block and the 31161111 SHP are the two accepted Dart blocks.
Some Dart blocks do require a taller lifter if you are using roller lifters, as the lifter bosses are taller. The SHP block is listed as having the necessary dimensions and bosses to use OEM roller lifters and camshafts.
I've used and sold both. The biggest thing is knowing how to hone them. You also often have to kiss both the lifter bores and the main bores to suit your needs.
Old 09-10-2011, 06:59 AM   #7
carl hinkson
Liked 18 Times in 10 Posts
Thanks in advance.
Chad
Chad
Don't spen al the at money on a old block, Putting 8 sleeves in that block will put a lot of unwanted stress in that casting,
Go with the SHP block and just about all roller lifters now are tall and will work the older blocks and the newer ones with the taller lifter bores.
We machine alot of Dart blocks and are a dealer for Dart products and as Alan metioned they do need some work and we like to have the lifters to be used in hand and fit them if needed.
The Dart block is light years ahead of any OEM block when it comes to cylinder locations, lifter bore locations, and cam tunnel placement and deck heights ETC.
Good luck which ever way you go!!!!
carl hinkson is offline   Reply With Quote
Old 09-10-2011, 06:50 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
I don't think a 1975 Chevy "Stocker" engine uses rollers. He Must use a stock size (Diameter) hyd style lifter.
Adger Smith (Former SS)
Old 09-10-2011, 10:17 PM   #9
Greg Reimer 7376
Liked 719 Times in 220 Posts
I gotta question. Will the 31161111SHP blocks legal with a 327?While a 327 and a 350 share bore sizes and almost everything else,the 327's were all 2 bolt main.Also, do these come with bushed lifter bores? The crank I use is the large journal steel forging. I have a few of these, so that's not a problem. Just thought I'd ask.
Old 09-10-2011, 10:51 PM   #10
John Leichtamer Jr
John Leichtamer Jr's Avatar
Did NHRA change the rules about using a 4-bolt main sleeved block down to 305????
Hammer
John Leichtamer Jr is offline   Reply With Quote
