Liked 11 Times in 5 Posts
G,day Adger,
okay mate i understand what you are getting at with the detonation. Thank you! Cheers Paul |
#2 | |
I first thought of PM you but I decided that this should be a forum that we share and learn from. So what I will express is my observation and opinions. I hope some one can add to it and I learn even more. Yes I am aware that some people can have a dim view of someones else's opinion that differs from theirs but most of the time disagreements leads to more learning, and damn I need more learning. I am very aware, at my age, that my best learning is behind me and my most to learn is ahead of me but my ability to retain said information has decreased substantially. Thank goodness for notes. -=---Adger;;You must use the same honing oil that I do. The wife told me to strip off before I came In the house last nite. I really thought I was going to get lucky with my closthes off but she had my shower on when I got inside. HeHaw-- Yes I have tried the Daytona EgoIII or Wego or what ever it is and like every unit I have tried , some part I like well, some parts was Ok, and some parts I did not like. I never could find the resolution but I figure it must be a 12 bit by an accuracy of .1afr (again their number--I did not check). I did not like a total of 8000 bits. I want every data point and then I do with the data what I want. And as a result I dumped all data points into another data logger and finessed the data the way I wanted. I really like a unit to be accurate but what I want more than anything is one that will repeat time after time even after the sensor starts to slow down(which it will). That is one reason I want every data point. Then I can tell when the sensor is going away.. If you want more data I will try to help but there may be others on here that can help more than myself. Maybe I can learn from them. But let me get my note pad first. I did like it to run methanol. Great for that charles Last edited by Charles Rainey; 07-14-2011 at 11:22 AM. |
G,day Charles,
Thanks very much for the reply! When you finish checking out that 14point 7 unit would you mind giving me some feedback and your opinion on it, just had a look on their site and by the look of it it does some nice things, would like to be able to log some other inputs as well as it looks like it has a lot longer recording time. Thanks very much! Paul Dilley Last edited by tuffxf; 07-14-2011 at 06:19 PM. |
#4 | |
Adger If we do not watch we are going to tell our age. I too have seen my world change when I built the Tech Edge out of Australia. Was the first O2 I had seen but it was the tip of the ice berg. And you are correct on data overload. My dyno has 46 channels to log data. Hell when I make a pull Im thru for the day just to look at data and make decisions. My brain aint got but one channel and most of the time it goes in the wrong direction. And man are you ever correct on detonation. No way will I tune by O2 alone. Very often I will not even make a pull on the dyno unless the weather makes a change. |
