Old 04-15-2011, 11:39 AM   #5
George Wright
George Wright's Avatar
Liked 390 Times in 34 Posts
Default Re: Racepak for stick cars
You can create additional channels in your RacePak. Create a new channel for 1st gear, 2nd gear and 3rd gear. In each new channel you can apply a formula. For 1st gear divide the driveshaft rpm by the first gear ratio. This will give you the same graph line for first gear as if you had an input sensor. You can do the same for 2nd and 3rd, just divide by their corresponding ratios. Yes you will have to look at four different lines, instead of one "clutch" graph line, but you will get the same results. You don't need to do this for 4th gear since it is 1 to 1.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
