you would need a 632 to get a 2800lb. car to run 160
your funny!!!!!!!!!!!!! |
Liked 4 Times in 2 Posts
You mean everybody doesn't have a 600 inch motor????.......lol
ROCK
is it safe too run 170 in gas than hit the brakes when the other guy did it first???? |
Thats because his truck can run 150+. I agree with Regan, put a speed limit in place. 135mph in SST would be fine with me.LOL Taking the electronic throttle stops away may work also. I would rather see things stay the same and let SST race other classes at the same event. I personally don't think this poll has anything to do with the fans, but rather the increasing number of trashed cars and injuries from excessive braking. Until NHRA stops giving out pink slips and starts suspending racers nothing will change. If they lower the index racers will find a way to make there cars faster and you will have the same problems at a higher mph.
4878 SS/GA 66CHEVY II |
I vote leave it alone, They think by lowering the indexes the cars will be on the stop for shorter amount of time and therefore be in a better area of the track for traction. (lessen the amount of .90 wrecks) if you lower them give it a few years and see that it made NO difference bc everyone will still just go faster, and by making the cars faster means that the now average 175 mph S/C car would be an average 180mph car. If it happened I would rather crash ar 170 than 180 wouldn't you?
S/ST you want to FIX that class? How about "NO TUBE CARS" full body cars with full frames ONLY! Back halves allowed but must retain factory firewall and/or frame rails. And keep the Scotty rule because you wouldnt be allowing S/St guys to run other classes, you would be letting HITTERS go back into street. This would PISS OFF alot of S/ST racers when it becomes as difficult to win rounds as S/G and S/C. That is my only post / comment for this discussion (you all fight nicely amongst yourselves) |
#7 | |
Liked 11 Times in 6 Posts
HUH??? I think you might have PISSED them off all by yourself with that statement.
Kevin MacNicol 2120 STK & S/ST |
