What color paint keeps an engine cooler or does it make any difference at all?
Liked 481 Times in 158 Posts
I am thinking most will say Black
Liked 6 Times in 4 Posts
I heard many years ago, 'Da Grump said white........... Great topic for discussion.....
Liked 69 Times in 30 Posts
Doesn't matter what color you use. If you are painting , then emissivity of the paint is the key factor in heat removal by radiation(none nuclear), in other words you could paint it with clear on bare metal and it wouldn't cause any temperature rise. One of the reasons Helicopter Engines aren't painted, plus it saves weight.
25 years ago or so I was at a pretty big name engine builders shop and I mentionned that I noticed most of the engines they were building were painted black. So I said "I see that you guys paint them black to help dissipate heat ?" and he looked at me and replied " no we just use black so oil leaks won't show up so easily !".
#6 | |
Liked 1,573 Times in 580 Posts
The next option would be flat black or any dark matte color. One of the best engine paints in the market is the Caterpillar Flat Black engine paint, it takes a long time to dry, however, if the block is clean and prepped, the paint will outlast anything else in the market. Another good paint is the PJ1 Fast Black motorcycle exhaust paint. |
I use a heat dispersing coating applied by MACH Development. Intake, cylinder heads, block, radiator. There's a picture on members rides.
Other than that, I'm told flat black disperses heat best.
Jeff Lee 7494 D/S '70 AMX |
