Re: cc3 box shifting on time?
Originally Posted by dbochan
Yes, you would wire the shifter solenoid to stop B but make sure you use a relay in between the box and the shifter solenoid. The 1st timer is set for the "on " time to make the shift. The second timer is set to hold the shifter solenoid on for a set time to make sure the shifter has shifted into 2nd gear (1-2 seconds more than timer 1 is good). The 3rd and 4th timers are set to the same time which needs to be greater than the 2nd timer and cancel each other out. These timers work the same as for the inline T-stop on timer A. Are you going to be at Lebanon Valley this weekend?
All good info. FWIW, you can set the 3/4 timers to 0.000 and they are just ignored.
Chris Williams 6304 SC, TD, ET
