Mr.Yacavone,
I remember very well, and still have the articles from High Performance Magazine of your Project Eliminator 77 Firebird. I have a 78 T/A that I always thought could be a stocker someday and i have to credit those series of articles from the 90's as motavation. Could you please expand on why you feel a manual trans in a low compression 400 second generation firebird is not a good mix. It sounds like its not really a parts breaking or clutch issue to you but something else. Those cars are heavy and the motor limited in RPM so is it you cant put enough gear reduction into it to avoid the old spin or bog situation? Lets assume were using a bullet proof driveline and a good clutch. |
#2 | |
Liked 8 Times in 7 Posts
the biggest question is can i still shift? not the trans, ...me. i AM getting older...but i have NO desire to run an auto....i'm doing this for fun and, honestly, if it ends up being another "job",i'll run brackets (we've got a stick series out here... |
How come manual trans threads draw so many opinions ? With all this ratio talk how would a 2 spd ever get downtrack? ...Thanx Trevor
#4 | |
oh, i'm not saying that it's the desirable trans BUT i have it and it won't be going on the "good" engine... i think i figured out once upon a time if this car ran a 14 flat up here, it's be a record run... btw, the rear is an 8 3/4 mopar w/4.57 gears (8.5x26" tall tires, ain't room for anything taller or wider) |
