Old 10-27-2009, 02:05 PM   #1
Crisco
Liked 47 Times in 21 Posts
Default Lencos in SS
Over heard a rumor of Lenco's (planetary style) transmissions being allowed in SS next year. Anyone else hear about this? Supposedly the Hemi cars are pulling for this for 2010.
Crisco is offline   Reply With Quote
Old 10-27-2009, 02:16 PM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs down Re: Lencos in SS
I heard something about clutchless trans but running a Lenco is getting out of hand. S/S and stock is almost a joke already not to mention all of the modifications they are doing to the Hemi engine in SS/AH.
Old 10-27-2009, 03:21 PM   #3
Mopar Steve
Excellent! Maybe Mega Blocks and Merlins are next!!!
Mopar Steve is offline   Reply With Quote
Old 10-27-2009, 03:35 PM   #4
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Default Re: Lencos in SS
Why not? I know dad is tired of replacing gears, shafts, forks, sliders, and more gears all the time. Not from breakage, necessarily, just abuse.
While we're at it, titanium valves would be a good idea, also.
But there's a million things you could change. Where would you draw the line??
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 10-27-2009, 03:42 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Exclamation Re: Lencos in SS
History keeps repeating itself. Mostly tube chassis and Lencos started to be used in Pro Stock in the early-mid-'70's. And those cars originally started as SS's.
To put things in perspective, the Pro Stock records in the late '70's were in the low to mid 8 second range!
(Before the 500" limit.)
LOCOMOTION Racing
Old 10-27-2009, 05:21 PM   #6
bill dedman
Liked 6 Times in 4 Posts
And, the last car to hold the lbs./cu.in. Pro Stock MPH record (with MPH arguably being the most reliable HP indicator) was a 383" Hemi, run by John Hagen.
I think the Ford Cleveland was pulling more weight per cube than the Hemi at that time, though, so there's not really any way to compare engines; it's all apples and oranges...
Bill
bill dedman is offline   Reply With Quote
Old 10-27-2009, 05:28 PM   #7
Jeff Lee
Jeff Lee's Avatar
I hear rumor of "clutchless" manual transmissions, not planetary (Lenco type) transmissions.
My understanding is a planetary will probably slow down when compared to a Jerico / G-Force type transmission.
I would be all for it. The transmission looks identical to it's clutch type twin. It's only the internals that are different. Automatics can change everything, look at a Pro-Trans and all of their modifications. Then there are e-shifts, trans-brakes, etc.
Stick racers should have the same benefits and that includes clutch releases comparable to trans-brakes.
Jeff Lee 7494 D/S '70 AMX
Old 10-27-2009, 07:11 PM   #8
SuperStockDodge
SuperStockDodge's Avatar
Hmmmmmmmmmmmm, I don't like where this is leading to (just my opinion) It's bad enough as it is, just taking more and more "drive" out of the "driver" What happened to manual transmission drivers in Stock & Super Stock that actually had to use their coordination skills after they dropped the clutch on the starting line. Might as well allow clutchless transmissions (since most drivers don't use the clutch anyhow) but as far as lencos, give me a break! I could just see a few more years down the road, air shifters would be allowed for the lencos and we would have to start certifying the harness/bracket that holds the CO2 bottle. I LOVE Super Stock, we don't need to take anymore of the (stock) out of Super "Stock". There is plenty of "Super" in the class already. Clutch/Transmission technology has come along way in the last 10 years, whoever said a (clutch assisted-manual transmission) car was less work than a automatic car? We need to just keep things the way they are and if someone wants a lenco-go run Comp or P/S...
SuperStockDodge is offline   Reply With Quote
Old 10-27-2009, 07:25 PM   #9
james schaechter
Liked 1,443 Times in 302 Posts
I heard that the possiblity of a clutchless is there, but not a planetary. Just the split slider deal like Jeff said. It has to be voted on by the committee. I think it would be a step in the right direction for the modified guys anyway. At least a modified guy with a stick might have a chance against the weight break for autos.
I don't think the Lenco would be anyone's choice in SS even if it was legal.
James Schaechter 3163 STK
james schaechter is online now   Reply With Quote
Old 10-28-2009, 06:49 AM   #10
herbjr
Liked 83 Times in 32 Posts
One thing about a Lenco it would never break. Why are guys worried about Lenco's when stick guys arent using the clutch now. They are pulling a lever. I had a lenco 20 years ago and I used it 2 years and sold it for more than I paid for it. It is slower than a clutchless no doubt, but how much is stock anymore anyway. I have a pro trans 904 Chrysler that takes a Chevy Convertor. Its so far out who really cares anymore.
Herb Jr
herbjr is offline   Reply With Quote
