Old 01-10-2009, 04:21 PM   #1
kingsransomracing
Default Spark Plug Indexing
With indexing the AR3933 spark plugs. If the crush washer does not give it the right position and you install the moroso washer (1 of 3) are you supposed to reinstall the crush washer or leave it off the spark plug since you have a indexing washer on it?
kingsransomracing is offline   Reply With Quote
Old 01-10-2009, 06:46 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Spark Plug Indexing
I've always lrft the washer on the plug, makes sense to seal against the indexing washer. Joe
Joe Buchanan SS/BX 3117
Old 01-12-2009, 10:55 AM   #3
randy wilson
Liked 22 Times in 22 Posts
what is the widest gap some run on their plugs and what benefit have you seen?
don,t have one
Old 01-14-2009, 06:48 PM   #4
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: Spark Plug Indexing
Randy, wide spark plug gaps went out with ignition points. With todays MSD's and most other manufacters electronics, there is no reason to run more than .025 gap. As a matter of fact, if your trying to run, say .040 - .050, close the gap down to .020 - .025, and you'll see a performance gain. At least that been my experience. ( and don't forget to have your plugs Cryo'd. - go kart trick! )
Jim Bailey is offline   Reply With Quote
Old 01-14-2009, 06:57 PM   #5
FED 387
Liked 329 Times in 177 Posts
Exclamation Re: Spark Plug Indexing
on AR3933 plugs leave the gap alone --run em as they come from the factory just check to make sure that the gap did not close up ratteling around in the boxes---Comp 387
Old 01-14-2009, 07:01 PM   #6
Bill Grubbs
Liked 564 Times in 66 Posts
"( and don't forget to have your plugs Cryo'd. - go kart trick! ) " - Jim Bailey
Hey Jim,
Is there a shop you would recommend for doing this?
Bill
Bill Grubbs is offline   Reply With Quote
Old 01-14-2009, 08:00 PM   #7
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Talking Re: Spark Plug Indexing
Bill I think their's some guy up in Ohio that dose it when he's not playing with a nitro funnycar!
Old 01-14-2009, 09:39 PM   #8
69Cobra
Liked 2 Times in 2 Posts
Come on now guys... what's the reason or benifit of cryo treating plugs?
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 01-14-2009, 10:50 PM   #9
Bub Whitaker
It keeps em cool...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 01-15-2009, 11:22 AM   #10
quickford1
Liked 20 Times in 12 Posts
I don't know about the cyro , but I do sell alot of Autolite AR 3910X and AR3933X to the go cart guys. It's a surface gap plug that has proven to be worth some big gains on their dyno.
Rich
quickford1 is online now   Reply With Quote
