Old 12-18-2008, 12:21 PM   #1
Smitty
Smitty's Avatar
Default Who's the best with a Super Stock convertor rebuild?
I have an 8 inch TCT convertor in my car that needs freshend I think; who do you guys think is the best out there. I have 72 Ford Mustang, 313 nhra rated open chamber cleveland, C-4 with 2.46 low gear, 6.20 gears, convertor currently will flash 6100 but I think I need to be a little looser as my peak power is in the upper 8000 rpm range.
Smitty is offline   Reply With Quote
Old 12-18-2008, 01:09 PM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Who's the best with a Super Stock convertor rebuild?
I use Coan for my bracket stuff, talk to Art Reed, but you may want to talk to ATI and compare, they seem to be able maintain great slip percentages even on loose stall converters.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 12-18-2008, 01:47 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Smitty,
I have been running an ATI converter since the early eighties. As a matter of fact that is the converter that I have in the car now. I had it rebuilt by ATI about 3 years ago. I would highly reccomend ATI. I also use some Coan parts in my powerglide. They are very helpful and easy to work with. I think either one could build a good converter for you.
Mike Pearson 2485 SS
Old 12-18-2008, 02:14 PM   #4
ati
Last edited by Alan Roehrich; 12-18-2008 at 02:17 PM. Reason: it keeps changing my post to all lower case letters
Old 12-18-2008, 02:39 PM   #5
Smitty
Smitty's Avatar
Smitty,
Thanks guys, that's kind of what I was thinking ATI, what do they get for a freshen up? TCT wants $325 for a freshen with updates which I think is a pretty fair price.
BTW, I got the trans out Mike, Rebel is going to have it looked at by one of his friends to see what the issue is with it. I figure while it was out I should probably have the convertor looked at.
Old 12-18-2008, 03:16 PM   #6
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Hi Smitty, I'm Lenny, formerly of TCT. Depending on when you purchased your TCT converter, I probably sold and built it for you. I overhaul and update most brands myself at our new facility.If I can be of any help, feel free to contact me personally.
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
Old 12-18-2008, 03:51 PM   #7
Ed Wright
Ed Wright's Avatar
Ati
Ed Wright 4156 SS/JA
Old 12-18-2008, 03:52 PM   #8
Mike Pearson
Smitty,
As I remember the price of the rebuild on my converter was about $350.00. It was an extensive reconfiguration to up the stall speed from about 5400 to 6200. Alot had to be changed. They wont know what they need to do with your converter until they cut it apart and see how it is set up. My converter was an ATI to start with. ATI keeps good records for every converter they build. You can call them with the serial number and they can tell you exactly how it is set up and how it will work with a certian combo. I am sure the other converter companies do the same type of record keeping. I have only used ATI. Jay has a Munsinger in his car. It took him forever to get it back from Munsinger when he sent it for a rebuild. ATI turned mine around in 24 hours.
Old 12-18-2008, 04:30 PM   #9
Smitty
Smitty's Avatar
I'm calling you right now, thanks!
Old 12-18-2008, 04:39 PM   #10
Smitty
Smitty's Avatar
Smitty,
TCT had a record of who the convertor was built for, it was initially built back in 1998 and overhauled in 2002. The convertor was actually built for a 306 nitrous engine, as it turned out it was pretty close to what I needed. I am going to call the gentlemen at Ultimate and see what he has to say since he might be familiar with the convertor.
I heard that Munsinger were good convertors and was offered a used peice for around $600, we will see.
Are you freshning up your engine this winter?
