Old 11-13-2008, 01:20 AM   #11
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: 1996 Powerstroke Dies Intermittently
My 94 Powerstroke with a stick would intermittently die if you touched the throttle just right, it is a throttle by wire deal.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 11-13-2008, 12:28 PM   #12
JeffM
Liked 5 Times in 5 Posts
Hopefully it is just the cam position sensor which is the most popular problem. Another issue is behind the primary fuel filter on the top of the engine, there is a small part about the size of a small cup. Unscrew it and there is a screen that can become plugged with debris, rust etc that can effect fuel pressure. Before finding this it killed my fuel economy.
JeffM is offline   Reply With Quote
Old 11-13-2008, 01:50 PM   #13
njk53
Trace your fuel pump wires in the harness. A friend of mine had an issue with the wire harness being pinched at body drop at the assembly plant. The fuel pump wire got chaffed and would ground out when conditions were right. His problem was intermittent like yours. He took it to the dealer once and they couldn't find anything. The second time it happened, Ford had a bulletin out on it. Call the dealer and find out from them, they will tell you what models were affected.
Nelson Kowal
Stock 345
Old 11-13-2008, 04:26 PM   #14
5774STK
Liked 9 Times in 6 Posts
There cam sensor is under factory recall. You can take your truck to your local Ford dealer and they will replace it for you free.
Jeff Johnson
5774STK is offline   Reply With Quote
Old 11-15-2008, 04:18 PM   #15
Joey
My 97 did the same thing, changed the cam sensor and the problem went away, I keep a spare in my glove box, of course Ford sent me a recall notice about two weeks after I changed it. I put Champion glow plugs in mine, they work fine. Be careful removing the valve covers as the gasket is also the injector wiring harness.
Joey
Joey is offline   Reply With Quote
