Is the largest needle and seat available the .149? With all the talk about the difficulty in keeping fuel in the bowl of our q-jets, certainly someone somewhere has designed a larger needle and seat than the .149.
I am not a class racer, but rather a stock appearing racer so I have more latitude on what I can do internally and externally to the carb, but much less latitude on how I plumb my fuel system. In a nutshell, I have to run "through" the stock pump, and "through" that factory 3/8" line to the carb, but from the factory pump back its no holds barred. I just think it would be a big help if someone made a larger needle and seat. Like a lot of other guys, I have fought a lean condition with this carb forever. Also, I run a front inlet '73 800CFM Buick carb. Any pointers on how to make the 90 degree turn from the inlet to the needle and seat more efficient? Great site and thanks for all of the ideas I have already picked up from all of you. |
Liked 56 Times in 27 Posts
Jim,
You need to contact Danny Ashley @ 765-674-5102, he is one the best on Q-Jets in the country... I sure he can help you with any problem you have... good luck, best time to call is between 3-7 pm..........Dave,
Dave Ribeiro 1033 STK |
Liked 110 Times in 29 Posts
Thanks for the compliment Dave but right now I have laryngitis and won't be speaking to anyone until probably next week. You know the old saying," When you talk you're saying something that you already know, but when you listen you might learn something." I can use some extra smarts. Danny
As far as I know the Edelbrock one is the largest , correct ?
Bud Lefevre 3075 STK IHRA World Record Holder |
#5 | |
Also, cant a bigger needle and seat be made for the qjet or is there some reason that it wouldnt be feasible? Or am I barking up the wrong tree again? Danny, I will give you a jingle next week when you are feeling better. |
#6 | |
Liked 231 Times in 107 Posts
Email me direct. |
There is a guy by the name of Sean Murphy out of Huntington, CA who has .150s.
Liked 333 Times in 180 Posts
try Val Hedworth @ 660-385-2536 too he may be able to help--Comp 387
