Old 11-06-2008, 03:25 AM   #1
HQS
Default Muncie trans help
Can somebody tell me if the shift fork shafts that go through the muncie side cover can be changed from the ones that have a stud to the ones that use a bolt to hold the shift arm on? I exchanged the ones with a stud for the ones with a bolt with a friend who was restoring a 66 nova. When I tighten the shift arm down, it binds on the sidecover and won't move. Is there a difference between the two shafts.
Thank you,
HQS
HQS is offline   Reply With Quote
