#11 | |
Liked 1,583 Times in 582 Posts
(P/N 408) The shift pattern is P N/R 1 2 3 N, reverse is neutral position with trans-brake engaged. http://www.precisionperformance.com/power1.htm http://www.precisionperformance.com/faq.htm#faq8 |
#12 | |
#13 |
If engine braking is suposed to be so bad, I wonder what kind of damage all of the top end womp womping is doing?
#14 |
Liked 244 Times in 26 Posts
I think the main issue is making sure the oil sump stays covered during decel is the main issue, wheather you click it at the finish line or just let off the gas.
#15 |
What about the lubrication circuits in an automatic trans, rolling 100+ mph with no lube supplied by the pump when you click the engine off?
I put my TH-400 in 2nd range at the stripe (no braking) and let the engine idle. Someone scared me out of taking it to neutral as I always had done previously. I don't like the engine braking, because free load rpms are always bad, in my opinion.
"Despite the high cost of living, it remains popular." Dave Cook NHRA N375 Last edited by Dave Goob Cook; 11-04-2008 at 01:04 PM. |
#16 | |
Liked 101 Times in 27 Posts
read the engine braking section on the Turbo Action website and let me know what you think.......it gives a list of transmissions and whether or not they have engine braking.....is that for all transmissions or just turbo action ???? |
#17 |
Scene lots of nice cars torn up playing with the shifter at the traps!!!!!!!!!!!!!!!!!!!!!!!
Chip |
#18 |
...and the reason why I recommend the Precision Performance Products Shifter...a very nice feature to have the ability to shiftl to Neutral after high gear. I wished they had the same feature for other transmission makes.
#19 | |
With a TH400 that uses a Transbrake and no front band, would that harm the engine lifting in high gear past the lights and getting on the brakes to slow it down with the ignition and fuel still on?? |
#20 |
Liked 5 Times in 3 Posts
My car is an auto...rev. valve body no brake. Thing is my valve body had no drag in 1st or 2nd gear so i can just shift it up to neutral.
