Liked 11 Times in 8 Posts
Mike, I've seen quite a few power steering pump shafts twist off, the pulley may still be there. Try pulling forward on the pulley, if it moves forward the shaft is broken. If it does not then you need to have the system tested for power steering pressure, most shops have the correct tools to perform this test. Hope this helps. Joe Buchanan
