Old 04-19-2007, 08:35 PM   #2
peter macritchie
Default
Have you tryed to put one of those coolant pressure tester pumps on the neck of the radiator where the cap twists on ?? Pump the plunger a few strokes to build a few pounds and see if it bleeds off by looking at gauge. Take off valve covers while under pressure and look for any water bubbles coming up thu the casting around springs & studs. Also drain oil & leave pan plug out while still under pressure. Block could be cracked at bottom of cylinder with coolant leaking into pan which will come out the open plug hole .Also leave spark plugs out and while under pressure possibly crank engine around and look for collant coming out any spark plug holes which will determine what cylinder may be the problem
peter macritchie is offline   Reply With Quote
