Guest
Posts: n/a
Putting together a GT/C '94 Camaro with a Jerico for IHRA Stock Eliminator ('71 LT1 350/330). Would you recommend running a cast crank? Solid lift cam should pull to 7,000 rpm. If not, should I just by-pass trying to find a GM steel piece and go aftermarket? If so anyone recommend a particular brand that they have had luck with or one that I should stay away from? I've heard the cast is lighter than the forged but was wondering if it would live behind a 4-speed.
Thanks for the help! |
Liked 70 Times in 29 Posts
You have to use the crankshaft that came from the factory in that engine.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 346 Times in 126 Posts
I would go cast, I know of many of SS cars that use cast and thier cranks last under must harsher conditions.
Liked 1,827 Times in 414 Posts
If IHRA Stock rules are like NHRA Stock rules, you must use a factory forging or casting. You can use a GM forged crank, that's what I'd run for the sake of longevity. A cast crank MIGHT be a little faster, but it'll be measured in hundredths, if at all.
Alan Roehrich 212A G/S |
Liked 1,429 Times in 297 Posts
I have been tempted, but the thought of taking the crank out in 3 easy pieces keeps me from going cast. Must be factory crank. Remember, your crankbone is connected to the transmission bone etc. with a stick!
James Schaechter 3163 STK |
Cast crankshaft, properly prepped is fine for that application... won't last any less than forged GM crank prepped the same. GM forged cranks aren't made of premo material and I have probably seen more cracked steel ones than cast...Make sure you select a core that has good cheeks on the top of the rod throws and good oil hole placement on the rod & main journals. Important to find a crank grinder that knows what he is doing as far a journal radius and to further enhance the life of your bearings, it helps emencely to have the crank surface hardened \ nitride or equivalent...
Liked 113 Times in 9 Posts
Bub, that is way you are the man,
Joe DeMarzo 1317 STK |
So Joe.. thanks for the vote of confidence.. just another post to get me to senior status like you are... unless Admin will just grant it...
Liked 4 Times in 4 Posts
With an automatic I would say it's a toss-up on the crank.
I would be leery of a cast crank in a high-horsepower stick car. |
Enlighten me...since you opened this thread again, others would would like to hear your experience
Bub Whitaker |
