Old 07-30-2008, 01:36 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: Total Seal gas ported ring spacer?
I've known a few that have gone this route. Seems to work.
This is another one of those ideas that while legal, just make the racer spend more.
Jeff Lee 7494 D/S '70 AMX
Old 07-30-2008, 11:10 AM   #2
RJ Sledge
Liked 288 Times in 90 Posts
I just talked to Adrian Pendergrass @ Precision Measurement Supply (210-681-2405) and he makes a fixture for doing them yourself. $140.00 and includes the Carbide End Mill. That way you only need the spacers ($30.00) and you can make all you want. Mill access would be needed. Give him a call and check out his web page Precision Measurement Supply.
RJ Sledge is offline   Reply With Quote
Old 07-30-2008, 07:50 PM   #3
Woodro Josey
Liked 3 Times in 1 Post
RJ, i have been using them for a while and i had to machine my own spacers, now they are machining them and yes they do work!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 07-30-2008, 09:53 PM   #4
RJ Sledge
Appreciate all the info everybody, I am going to try them. Thanks RJ
Old 07-30-2008, 10:05 PM   #5
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Total Seal gas ported ring spacer?
R.J.
Back in 1961 there were some Mercury pickups built in Canada that had an FE engine with gas ported pistons. They were also equipped with a C-4 transmission. I would petition the NHRA for the rightfull parts that should be superceded for your car based on that truck from 1961 so that you can just run a gas ported piston instead of all those high tech expensive ring spacers.
Jim C.
Jim Cimarolli is offline   Reply With Quote
Old 07-30-2008, 10:12 PM   #6
Chad Rhodes
Originally Posted by Jim Cimarolli View Post
R.J.
Jim C.
you crack me up Jim
Chad Rhodes 2113 I/SA
