Old 07-06-2008, 01:13 PM   #1
Bernie Cunningham
Liked 52 Times in 17 Posts
Default Re: ECU Help???
How's your fuel flow, filter, pressure?
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
Old 07-06-2008, 01:37 PM   #2
art leong
Fuel pressure is 43.5 psi using a Aeromotive 1000 pump fiters are all new just 2 runs on the car.
No problem with acceleration because I can't get the tires loose in the water.
The air/fuel ratio starts way lean then gets "normal" when the car cleans up at about 4500 rpm in gear.
Art Leong 2095 SS
Old 07-06-2008, 02:33 PM   #3
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
Hey Art, there are a bunch of very knowledgable tuners of 2.2, 2.5, and 2.4 as well as 2.2 hybrid cars on http://www.turbo-mopar.com/forums/cmps_index.php Go over there and ask and I'm sure one of the calibration or standalone "experts" could help you out.
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
Old 07-06-2008, 07:33 PM   #4
Ed Wright
Ed Wright's Avatar
Art, your air/fuel ratio will look extrememly lean at lower RPM, due to fresh air being pulled back in the collector during overlap. You need to put a muffler, or at least 18" of collector extention to know what the actual air/fuel ratio is at idle, on the converter, and launch. Once you get that dialed in you can remove it to race it. Be sure, if you are going to run it in closed loop to set the min RPM for closed loop fuel corrections higher than the RPM you will stall it on the converter. Otherwise the ECU will be pouring the fuel to it down there to try and correct what it assumes is an extremely lean air/fuel sistuation with the exhaust extention gone. If you can put a bend in the extention, that would be even better for the initial low RPM air/fuel tuning. I no longer run my FAST in closed anyway.
Good luck, Ed
Ed Wright 4156 SS/JA
Old 07-06-2008, 07:59 PM   #5
art leong
Hi Ed. You might be on to something with my problem. Is it posible the open loop parameters are messed up. And when it gets up there in closed loop it straightens out and runs fine?
Art Leong 2095 SS
Old 07-07-2008, 09:54 AM   #6
Ed Wright
Ed Wright's Avatar
Could be Art. Set the min temp or min RPM for closed loop exttremely high, and get the fueling corrected in open loop with the muffler or long header extention installed. If you get it running well warm, but it has problems cold, only change the temp correction tables to address that, or you will be changing your warm/no temp correction tuning. Remember to not let it run in closed loop at low RPM with open headers.
Old 07-10-2008, 03:09 PM   #7
NovaMan
NovaMan's Avatar
Just out of curiosity, is this a speed-density system or mass airflow?
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
Old 07-11-2008, 11:17 AM   #8
art leong
I'm using open loop all the way through.
Art Leong 2095 SS
