Old 06-27-2008, 09:24 AM   #1
FED 387
Liked 330 Times in 178 Posts
Question cleaning transmission cases
Any suggestions on how to clean 1000's of miles of road grime oil/grease and crud off the outside of stock aluminum automatic transmission cases??? I just picked up several and want to get them cleaned to do a race trans build up----Can you clean them like a iron block that is bake them and then blast them or will this ruin the machined passages in the case???? I,m sure the trans shops have a way of cleaning them just need to find out how or what they are doing---Thanx Comp 387
Old 06-27-2008, 09:46 AM   #2
SSDiv6
Liked 1,568 Times in 579 Posts
Default Re: cleaning transmission cases
Steam cleaneer or vapor degreasing machine. Do not bake them.
Old 06-27-2008, 11:51 AM   #3
bob gonier
A friend of mine just got out of the Soda Blasting business and to tell you the truth that was the best way to clean anything greasy. He Soda Blasted a few trans for me and they come out looking BRAND NEW. All the factory markings remain and the different contrasting metals all look new. Its really pretty amazing. Do a search for local Soda Blasting and have it done with the water.....Its that nice and worth the effort.
Great for blocks and heads too !!!!!!!!
Just an idea..................
bob
bob gonier is offline   Reply With Quote
Old 06-27-2008, 01:33 PM   #4
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
The very best way is on the driveway, that way your wife can walk thru it and then get into her new car. The look on her face will be priceless. Ask me how I know
Daran Summerton is offline   Reply With Quote
Old 06-27-2008, 02:48 PM   #5
NHRA3106
Liked 143 Times in 37 Posts
Cool Re: cleaning transmission cases
The simple shadetree way, which you may be aware of, is to simply use Easy O.ff oven cleaner. Just coat, let sit for awhile, and rinse. Using a pressure washer to rinse is even better. With no tank, I always final wash inside and outside with Dawn dishwashing liquid. My cases always clean up great. Of course I'm only doing my own and not a hundred customers.
NHRA3106 is offline   Reply With Quote
Old 06-27-2008, 04:08 PM   #6
Paul Precht
Paul Precht's Avatar
Liked 309 Times in 118 Posts
Daran, you and I think alike, Paul.
Paul Precht is online now   Reply With Quote
Old 06-27-2008, 06:07 PM   #7
Liked 1,784 Times in 407 Posts
Oven cleaner will remove most of it, given enough time to soak, and if it is kept warm. Then wash it at the car wash if you don't have a high pressure washer.
Often you'll need to soak them for a while, and it helps a lot to knock off all the heavy, thick, loose stuff, before you try the oven cleaner. The "purple power" stuff works well, as does "Simple Green", used in high concentrations (at least 50/50) after the oven cleaner has been used.
If you use "caustic soda", like you'd see in a machine shop for cleaning cast iron, the aluminum case will contaminate the solution, and make it foam. It will also make the case turn dark. The case can be brightened up with etching mag wheel cleaner, AKA phosphoric acid.
As to what transmission shops use, most use a high pressure spray cabinet, with the solution about 180 to 200 degrees, and one of the best soaps is Safety Klean floor soap (the 666 stuff).
Old 06-28-2008, 08:54 AM   #8
BillK
Liked 30 Times in 17 Posts
Fed,
Most transmission shops have a large spray wash cabinet that the clean them in. See if your machine shop has one, we have done a few for one customer that builds his own transmissions. Its the same machine we use to clean aluminum heads.
Bill Koustenis
BillK is offline   Reply With Quote
