Old 06-25-2008, 05:56 PM   #1
FED 387
Liked 332 Times in 180 Posts
Default Re: starting problem
Try a different battery that you know is good before replacing the battery(s). Are you sure the starter is good ??? Next make sure you have a good clean ground for all the electronics and the battery---Make sure you have the ground wire going from the MSD grounded to the engine as well as the frame of the car---This is very important to do---Se if this solves your problem
Old 06-25-2008, 08:52 PM   #2
mdspray1
Smile Re: starting problem
try to diconnect alt.or change key switch (if used)
mdspray1 is offline   Reply With Quote
Old 06-25-2008, 09:27 PM   #3
Jim Carter
Liked 19 Times in 3 Posts
I had a similar problem years ago. Charlie Ford told me to ground MSD neg. cable straight to battery ground. Problem solved. I repeat: Problem solved. Thank God for the internet!
I also ran extra grounds from engine to chassis.
Think: Ground.
Jimmie C.
Jim Carter is offline   Reply With Quote
Old 06-25-2008, 10:21 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
MSD electronic distributers usually get pretty rusty at the reluctor and other areas and I know one person that had a pickup go bad causing his engine to miss. Poor grounding is definately a possiblity as well.
Rich Biebel
S/C 1479
Stock 147R
