Old 08-05-2025, 12:45 PM   #7
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 225 Times in 96 Posts
Default Re: Notice to Numidia racers
Originally Posted by dragracerray View Post
Mark Dawson (Div1 Director) contacted me. I want to understand "True Start" better. Mark says, "YOU CAN HAVE 2 RED LIGHTS IN ELIMINATIONS OR QUALIFIERS". So I assume that when 2 red lights occur in eliminations the timing system decides who redlighted first? Are there other changes I might not know?
TrueSTART has become pretty common in bracket racing, but it will vary by track or race promoter.
When the first car leaves, the light will ALWAYS turn green. When the second car leaves, the lights will remain green if both drivers were green, or one/both red lights will turn on if either/both drivers were red. The winner will be the driver who was red by the least amount. The way it should be, IMO, although I've never heard about it being approved for use at the NHRA divisional/national level.
If you're the slower car, you just need to be sure to check for winlights after the quicker car leaves.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
