Old 08-03-2025, 08:09 PM   #1
BTR69
BTR69's Avatar
Liked 74 Times in 24 Posts
Default Clutch fork & pilot bearing question
Good evening. Please forgive my lack of stick shift and clutch knowledge, but I haven't done much aside from driving a manual tranny since the late 1990's. Looking for input on the correct orientation for installing this shift fork. Pretty sure the flat side (top in pic) goes toward engine and angled side toward tranny. Or does it really make much difference. Just want to verify if I'm correct, as I've apparently lost my reference pics from disassembly.
Also, the pilot bearing is different than the original. Does it matter if the groove is one way or the other?
Thanks.
Name:	clutch fork.jpeg
Name:	pilot bearing.jpeg
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
Last edited by BTR69; 08-03-2025 at 08:14 PM. Reason: forgot to select instant email notifications.
BTR69 is offline   Reply With Quote
Old 08-04-2025, 02:17 PM   #2
james schaechter
Liked 1,436 Times in 299 Posts
Default Re: Clutch fork & pilot bearing question
It looks like the fork was clearanced a bit to clear the hat so that should face the hat of the clutch
I doubt of the groove was anything other than a a groove for an o ring in case the bearing is used in applications that may require it. Should not matter which way the groove is in this application.
James Schaechter 3163 STK
james schaechter is online now   Reply With Quote
Old 08-04-2025, 09:02 PM   #3
BTR69
BTR69's Avatar
Thanks. Had not considered being machined for clearance. Makes a lot of sense. Did an internet search for this style fork and found one from Quarter-Max Racing that looks identical, aside from where mine is shaved down. Hopefully I'll have things back together in the next few days.
Have a great week.
William Kilduff
1968 Camaro SS/C
