Old 06-08-2025, 10:40 PM   #1
Dewdlebug
Liked 23 Times in 15 Posts
Default Re: Weather station paging interference
Over the last few years I've have similar scrambled pages, or no page at all, but mostly at Nat Events. I too reached out to Altalab and was informed that someone was over-powering my little 5 watt transmitter inside my unit. They suggested that I move my antenna location to see if it would help. My antenna is permanently mounted to the top of my trailer but I had a spare antenna from an old Performaire with a 25' cable which I was able to connect and after moving it in what seemed to be 100 different locations, 6" at a time, I finally found a sweet spot and got back in business. It was easy to see when I was being "jammed" by watching the red light on the front of the Altalab base unit. When it stays on constantly you're not getting out.
Altalab said that its more prominent at Nat events. I've seen it where we run TT on Thursdays with no issues only to have NHRA.TV set up all their bs and then there goes the signal. I've thought about moving to a text system but I've seen the cell service at Nats so bad before that you can't get through at all on a phone, text or otherwise.
Dewdlebug is offline   Reply With Quote
Old 06-09-2025, 01:53 PM   #2
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 226 Times in 97 Posts
Ray, have you ever noticed that your prediction pages will be incomplete or garbled, but the pages that contain only weather information sent from the Altalab unit will usually be complete?
That's something I have noticed.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 06-09-2025, 06:39 PM   #3
SST159
Liked 20 Times in 16 Posts
Tony,
That is exactly what happens to mine.
Fortunately the texting works for me so I will stick with that.
Only issue I have with texting is that after I shut everything down and go home, I keep getting prediction texts for sometimes days and then it finally stops.
Pretty weird.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 06-13-2025, 04:03 PM   #4
Lenny5160_v2
Originally Posted by SST159 View Post
Tony,
Pretty weird.
I assume that the texts coming in later are "missed" texts from race day?
I would guess the prediction texts are sent through a similar system that NHRA uses to send updates during events. Those types of messages (through the internet and not phone-to-phone) are sometimes held up by phone companies as potential spam.
Tony Leonard
S/ST 56
S/C 53
Old 06-14-2025, 08:00 AM   #5
Keith 944
Keith 944's Avatar
Tony,
Pretty weird.
Come see me at Lebanon I want to show you something
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 06-14-2025, 10:27 AM   #6
SST159
Will do.
Drew Wonderly
SST 159
