Old 03-29-2025, 08:05 AM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Harmonic Balancer bolt
Looking for options on turning sbc super stock motor by hand. Pretty much have used a high grade 7/16? fine thread bolt in the past, but with today?s spring pressure, and not wanting to always remove plugs my comfort level using just a bolt is not high. I?m concerned using a long bolt with 5/8? socket head going thru pulley for alternator, crank trigger wheel and balancer is super stressing threads. Is there something out there that?s keyed with large nut to relieve stress on threads? What are others doing to turn by hand? Thanks. Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 03-29-2025, 08:26 AM   #2
tavirace
Liked 18 Times in 13 Posts
Default Re: Harmonic Balancer bolt
I recently picked up a Chevy 350 for race engine build , it has a good standard crank but someone in the past had stripped the bolt and redrilled it to 1/2 fine thread. I think it looks ok but machinist didn't like it , felt it would weaken it in that area.
tavirace is offline   Reply With Quote
Old 03-29-2025, 08:45 AM   #3
pmrphil
Liked 345 Times in 149 Posts
That bolt should be torqued somewhere in the 65-70 lb. range - if it takes more than that to turn it over, that would be a bigger issue. Spring pressure really doesn't come into play unless you only have some of the springs installed.
Phil Molski
PMR Performance
S/C 1623
Old 03-29-2025, 09:25 AM   #4
Kevin Panzino
Kevin Panzino's Avatar
Liked 739 Times in 135 Posts
I use a stud and 15/16? nut kit that Callie?s sells. The large nut has a bunch of surface area to grip on the balancer. Never had an issue and it?s very nice having a stud and nut for the snoot threads rather than a bolt.
And yes, big springs do make it harder unless you have roller cam bearings, because the cam is down hard on the Babbitt with no hydrodynamic wedge yet while just turning by hand.
Kp
Old 03-29-2025, 12:46 PM   #5
Ed McLawhorn Jr.
Kp
Kevin, hadn?t thought about a stud. Yes, I have babbitt bearings and it?s harder to turn.
Old 03-29-2025, 01:47 PM   #6
Kevin Panzino
Yes, its a very nice setup. They make them in a bunch of lengths, so you will have to do some measuring to get the correct length. I have heard ARP makes these for Callies, but I am not sure. I can tell you, its not Chinese junk, (speedmaster etc). I've had the same one for probably 15 years now and its as good as new. Black Oxide isnt even barely worn off of the threads.
Link below.
https://www.callies.com/components/stud-kits/
Kp
Old 03-29-2025, 01:55 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,900 Times in 570 Posts
I have the ARP balancer bolt. Works fine for turning the engine by hand. 350 seat pressure on my springs. I do have roller cam bearings and that does make hand turning a bit easier but has no real performance gains.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 03-29-2025, 05:46 PM   #8
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Jones Racing Products makes an aluminum hub that bolts to your balancer and accommodates a large keyed nut (and custom drive pulley - you choose diameter).
T Ames is offline   Reply With Quote
Old 03-31-2025, 09:38 AM   #9
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 279 Times in 96 Posts
I use the ARP balancer bolt that has the 1/2 drive hole, just stick long 1/2 ratchet in and turn..
Old 03-31-2025, 01:23 PM   #10
Dirk Olson
Liked 170 Times in 45 Posts
Not sure about that, on a SS or Comp Combo @ 390 on the seat and @ almost a 1000 over the nose it is a struggle to pull the motor over by hand especially with the plugs in. we always bump it with the starter when checking valves. As far as a bolt goes use a ARP bolt, should good to go.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
