Old 08-18-2021, 10:00 PM   #11
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Cleaning an aluminum head
I will shell out some dollars for some shells and some carb cleaner and give it a try.
We have black walnut trees in the yard and to crack the shells it takes a big hammer and safety glasses.
I have about 100 black walnut trees, I guess they're good for something other than feeding the chipmunks and making a mess. The chipmunks make huge piles of them in the weirdest places and the next day they'll all be gone.
Old 01-20-2025, 04:51 PM   #12
bpete
Liked 19 Times in 4 Posts
I know this is an older thread but...
Is bead blasting or soda blasting within the rules for stock?
It's not SAND blasting after all.
Brad
bpete is offline   Reply With Quote
Old 01-20-2025, 05:02 PM   #13
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
I blast them with Walnut Shells or Baking Soda. Just make sure there is no oil on them, Castrol Super Clean and a garden hose hooked to your hot water tank makes de-greasing easy before blasting. Lots of times you don?t have to blast after Super Clean is used with a brass wire brush. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 01-21-2025, 08:43 AM   #14
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Glass beading works well if all oil is removed first.
Old 01-21-2025, 11:34 AM   #15
bpete
Thank You Maurice and Glenn ,
I will give both methods a try
Old 01-21-2025, 02:06 PM   #16
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by bpete View Post
I Is bead blasting or soda blasting within the rules for stock?
That’s funny. I can tell you that the stocker guys having their aluminum heads ported ain’t concerted about the rules, much less what method is used to clean them.
Old 01-21-2025, 03:22 PM   #17
CMcAllister
Liked 920 Times in 259 Posts
I have been told that GM Top Engine Cleaner is an excellent carbon cleaner. Especially tho older stuff in the red white and black can (#1050002). So much so that the firearms guys use it to clean up carbon fouled, neglected guns.
I have some here, but I have yet to try it out. And I see it on ebay as well.
Old 01-21-2025, 10:08 PM   #18
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
You can use Hoppe's #9 gun bore cleaner. You can get it a Walmart in the hunting section for a few bucks.
Ive used it to clean carbon off piston tops with a fine scotchbrite pad and it works great.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 01-22-2025, 03:54 AM   #19
Cglrcng
Cglrcng's Avatar
Liked 410 Times in 210 Posts
It must be Tuesday. Motor mouth out here tossing around some pretty wild and serious accusations, that I would bet any amount of money, he could not actually back up.
When people (social media haters specifically who must really have terrible lives for whatever reason), aimlessly just throw out garbage in print, they should really think first before clicking the send button.
It wasn't enough already that an NHRA Racer got banned recently from using their inked (and spent already social media sponsorship $$$), due to wild accusations that may or may not even have a single thread of truth to them (sure, could be or not with Only Fans, as much of it appears to be paid subscriber adult content...I don't know personally, but I also hear that some have channels there because they like to cook BBQ, work on/show cars, and others who just flat got tired of giving their hard work & internet content away for free on YouTube and maybe they are actually tired of getting
demonetized for their music or content choices. Who knows, the result was just sad to hear about for that specific racer. Just saying as adults let's deal with facts, not wild accusations and supposition. Lastly do not judge, lest ye be judged. Hot Button pusher. (See how easy that is...I was talking about your Trans brake).
Easy Off Oven Cleaner and a soft brush, or Chemtool Carb Cleaner both have my vote.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 01-22-2025, 05:53 AM   #20
1320racer
1320racer's Avatar
and again you'd be WRONG! Talk about what you know not what you think you know!!
