Old 11-15-2024, 12:13 PM   #11
west coast
Liked 175 Times in 59 Posts
Default Re: Bring back MINESHAFT RULE
I got in to this class because it a performance based class. Need more heads up racing, less classes combine auto and sticks. Enforce the rule book, more teardowns. Possibly 1lb weight break between the classes
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 11-15-2024, 12:25 PM   #12
Liked 1,291 Times in 323 Posts
Originally Posted by James Perrone View Post
Let the qualifying sheet tell you it?s mineshaft
Not the weatherman
Weatherman like politician can?t trust them
Also 120 under get an instant hit
Make class racing great again
I don't trust weathermen any more than I trust politicians.
However, an actual formula taking into account barometric pressure, relative humidity, and grains of water in the air is purely scientific.It tells you the true effect weather has on performance potential. Just like the SAE correction factors for an engine dyno. They're not perfect, but they're based on reality and scientific fact.
The qualifying sheet tells you how hard a percentage of people are pushing their combination, with weather as a contributing factor.
Old 11-15-2024, 01:22 PM   #13
442OLDS
442OLDS's Avatar
Liked 283 Times in 103 Posts
Let's say I'm at a race like St Louis where it is pretty fast.I get a heads up run and all I can go is about 8 tenths under.I'm going to get beat badly by my opponent since he probably can go 1.30 under.He gets a really bad light,tightens the stripe,and still runs 1.05 under.
With the mineshaft rule in effect where half the field was at least .85 under,he will not trigger? But if the mineshaft rule is not in use,he will trigger at one second under?
Is that how the mineshaft rule works?
Old 11-15-2024, 06:44 PM   #14
J.R. Haddad
Liked 1,193 Times in 244 Posts
I believe it basically follows the same rules as Indy with no AHFS, with
the exception being the instant hit ( was -1.20 now -1.30 ) is still in play.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 11-17-2024, 03:12 AM   #15
Adger Smith
Liked 824 Times in 301 Posts
IMHO the problem with the mineshaft rule is it was based on the field strength instead of the weather. Again, the field can be "Manipulated" and the weather is what it is. The question should be what weather conditions constitute "Mineshaft" I say start with StdTempPressure and move the threshold up...
Adger Smith (Former SS)
Adger Smith is online now   Reply With Quote
Old 11-17-2024, 01:24 PM   #16
Mike Pearson
Mike Pearson's Avatar
Liked 1,756 Times in 537 Posts
Mike, let?s put mineshaft where it once was when more than half the field Is 80 under whatever it was that?s telling you the weather is good for everybody
When the weather is killer, that?s when you need mine
Let?s go back to what we had
It only comes in effect when the weather is killer
I can agree with going back to what it was originally.
Mike Pearson 2485 SS
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
