Old 09-09-2024, 09:49 AM   #1
Signman
Liked 269 Times in 99 Posts
Default Re: Ppp shifter clean and relube?
Originally Posted by Signman View Post
My PPP shifter has been acting up on the 1-2 shift going past 2nd so disassembled it either it needed maintenance or was worn out
The original lube was full of dirt cleaned it all off everywhere
Don't mess with the handle unless you have some patience.
Used Super Lube silicon grease as the assembly lube
Soaked the cable in trans fluid for a few days
Re installed making sure alignment and adjustment are as instructed.
Initially my impression was the spring that pushed the rod/disc up needed to slow down but with bench testing and in the car before and after the shift lever needed to speed up. That must be why PPP states most problems are in the cable.
Cleaning and lubrication worked as expected.
No more shifter issue.
Old 09-10-2024, 12:08 AM   #2
tuffxf
Liked 11 Times in 5 Posts
Smile Re: Ppp shifter clean and relube?
Mine turned out great also!
Cheers
tuffxf is offline   Reply With Quote
