#11 |
Liked 7,032 Times in 1,584 Posts
Richie, add 1/2 qt. of fluid!
Billy Nees 1188 STK, SS What is "NORMAL"??? |
#12 |
Liked 717 Times in 209 Posts
The lag is somewhat inherent in some valve bodies but many times its due to improper fluid level .
Here's the link to the Turbo Action tech tip on proper dip stick measurement. https://www.turboaction.com/TH200Full_Mark1-04.pdf
#13 |
Liked 513 Times in 201 Posts
I’ve been working on the car all day
Ran it for a few minutes and checked the level and it was low It has a custom locking dipstick and someone marked it on one side for correct level Without pulling the pan I can’t confirm that dipstick is correct I’ll recheck it hot at the track next week. Car needs some TLC and we’re getting reacquainted.
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; Yesterday at 05:34 PM. |
#14 |
No cooler and No loop.....plugged at the trans.....Don't know if that could be an issue....
#15 |
Liked 696 Times in 271 Posts
Rich,
I don't know about a 200 but in a PG if you just plug the cooler lines off with out modifying the pump it causes a restriction in fluid flow out of the converter. Converter will function different with the restricted flow. Just Put a loop on it and see if it helps the issue.
Adger Smith (Former SS) |
