Old 06-17-2024, 10:09 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Smile 12 bolt info
will a 12 bolt Pontiac, Buick housing fit all my Chev gears, bearings etc. ?
Mike Savelle is offline   Reply With Quote
Old 06-17-2024, 10:40 AM   #2
SSDiv6
Default Re: 12 bolt info
Are you refering to the BOP 12-Bolt vs Chevy 12-Bolt?
The term "12 bolt" refers to the number of bolts on the ring gear, not the cover. The BOP "12 bolt" actually has only 10 bolts on the ring gear while the Chevy "12 bolt" has 12 bolts on the ring gear. Also, the BOP has a smooth cover and it is not scalloped like the Chevy cover. Internal parts are not interchangeable.
Old 06-17-2024, 11:49 AM   #3
Jeff Stout
Liked 708 Times in 285 Posts
Correct, they wont interchange parts.
Easy way to know which one you have is to look at end of axle tube where bolts to backing plate. If tube is straight and not tapered it's a BOP rear end.
If the last 3 inches of tube tapers down at backing plate its a chevy
Old 06-17-2024, 12:45 PM   #4
Mike Savelle
Smile Re: 12 bolt info
Thank you Class Racer , I will stay away from that ...
