Liked 205 Times in 93 Posts
SS/GT cavalier...not sure which way to go. any advice please...i plan to run an alternator.
Liked 2,487 Times in 698 Posts
I you need the weight anyway = Why not run a
second battery. We do in our cars.
Liked 3,193 Times in 975 Posts
What’s nice about GT is class flexibility, if you need the weight then what John said. If you’re looking to be able to move up in classes occasionally then it’s a lot easier (and cleaner) to just remove weight bars.
would any ony have a battery cable diagram to hook up two batteries using charging lugs and required kill switch in the system...tks !
Liked 805 Times in 245 Posts
I totally agree that if you need weight, might as well be a second battery. One piece of advice that I learned the hard way, between races, separate and load test the batteries individually. If one of the batteries goes bad, it will take the other one down with it.
#6 | |
if you must run two batteries consider running an isolator you could even put a switch inside the car in case one battery goes dead. Hit the switch and you’re up and running.
Liked 10,758 Times in 2,236 Posts
We run two batteries in the Cuda each weighing 11.5 lbs one in stock location one in the trunk. We lost a little weight off of the front. Dumbo only has one in stock location.
looking for wiring diagram for this application if anyone has one please
