Old 04-08-2024, 10:33 AM   #1
BIGG18c
Liked 35 Times in 14 Posts
Default S/G Launch RPM
I am finishing up re-doing a 27 Roadster I bought turn key in the fall. This is my first drag car to have a Trans-Brake and will be my first car to run on a pro tree. I was wondering if anyone could share what they are setting the launch rpm at on their cars to give me an idea were to start with mine. Hoping to license the first weekend in May! 509 BBC backed by a ATI ProGlide, Dana 60 4.11 gears. Thank you all in advance, this will be a huge learning curve coming from my footbrake 11 second nova.
Grant Christianson C521 S/G,S/C, Pro ET.
BIGG18c is offline   Reply With Quote
Old 04-08-2024, 11:48 AM   #2
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 216 Times in 93 Posts
Default Re: S/G Launch RPM
5000 is a decent place to start. First of all you need it to be high enough to cut a light, then you can play with it up or down according to what the car seems to like.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 04-09-2024, 11:12 AM   #3
JP1738
JP1738's Avatar
Liked 1,126 Times in 314 Posts
Lenny, that seems a touch high to me. Given its a big block roadster and likely pretty lite, I'd say it won't take much. I try to keep my stuff as calm off the starting line as possible to mitigate the risk of looping the tire or darting one way or another. I have mine set to 4200, but I have quite a bit more gear than this guy. It might take 5k to get it to move with a 4.11 gear, but I'd start low and work my way up if I had to.
I've got mine set up where I have just enough bulb to run .005-.010 delay everywhere I go. Prints 60ft tickets and never gives me the weenie, at least off the starting line.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 04-09-2024, 11:46 AM   #4
BIGG18c
Thank you both for the tips! The car is supposed to weigh 2300 with me in it. Have not fully finished it to get the scales out yet. I think I will meet you both in the middle and start around 4500. I do truly appreciate you guys taking the time to give me advice!
Old 04-09-2024, 12:56 PM   #5
Lenny5160_v2
That seems reasonable. Especially with getting used to a new car that is much different than you are accustomed to, starting low is probably a good choice. You can always bring it up if you need to.
Good luck with it!
I see you're a D5 guy; maybe I'll see you out on the trail this year. I should be at all of them.
Tony Leonard
S/ST 56
S/C 53
Old 04-09-2024, 12:58 PM   #6
Mark Yeager
Liked 36 Times in 11 Posts
I leave between 4500-4800. 2140 lbs. I carry .030-.040 in delay. Good luck!
Mark Yeager is offline   Reply With Quote
Old 04-09-2024, 02:01 PM   #7
BIGG18c
Good luck with it!
Lenny- I plan to license at BIR the first or second weekend of May then be at Tri State for the double National Open if all goes well!
Old 04-09-2024, 02:12 PM   #8
Lenny5160_v2
I may be at that second BIR weekend, but I'm always slow to get my stuff ready and get started.
Grove Creek for Memorial weekend should be happening, then Tri-State for the first divisional event.
Tony Leonard
S/ST 56
S/C 53
Old 04-10-2024, 02:29 PM   #9
JP1738
JP1738's Avatar
It's crazy that D2 will have had 4 divisionals before y'all have your first. This spring has been an absolute marathon between 4 divs and 2 nats, plus outs if you wanted to go to La.
Dawson Pauley
Old 04-13-2024, 12:50 PM   #10
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Same here in D7. Well kinda 3 nationals and 4 Diisionals for those that chase
sst7250 is offline   Reply With Quote
