Old 03-17-2024, 09:35 PM   #1
LS1Racer
LS1Racer's Avatar
Liked 6 Times in 6 Posts
Default Re: LT1 Opti spark question
Do you have a timing pointer on the engine? On the MSD opti at least on the fast xfi crank reference angle is set at 1 degree. I always use the fixed timing setting in the software to verify that the ecu and actual timing on the damper are the same. Looking at the BS3 it seems to be the same procedure except maybe for optispark crank reference.
Pete Muenzer 5948 C/SA
LS1Racer is offline   Reply With Quote
Old 03-17-2024, 09:43 PM   #2
e vassar
Liked 281 Times in 110 Posts
We will check. At this point we may just need to log some runs and try to figure out what is going on here. We have a T&T Sunday night at a local track,but it can be sketchy if you know what I mean.
Thanks for the help so far
