Liked 880 Times in 311 Posts
Do you run an electric water pump?
I had a pump go bad(Leak) at a race. I had a spare in the trailer. No issue because I had time to change between rounds. Next round I had a hi RPM stutter show up.. Changed the crank trigger pick up. Stutter is still there. Sat there in the pits and thought the problem through. Next round I kept the pump on during burn out and turned it off as I staged. No miss that run. When I got home I put a seal in the first pump and put it back on the car. No miss next time I ran the car. My conclusion is the pump was a radio station that produced RFI that interferes with the MSD. Probably the pickup since my V-6 uses a cam trigger and close to the pump.
Adger Smith (Former SS) Last edited by Adger Smith; 02-12-2024 at 02:01 PM. |
