Old 02-03-2024, 12:13 PM   #1
boydw2000
Default Super Stock Piston Compression Heights
Working on engine design and build for NHRA Super Stock. I was trying to find out if there are any restrictions on piston compression heights. Rule book states: "Replacement pistons permitted, provided they do not increase stock compression ratio and retain overall design pattern as
specified by automobile manufacturer." I have searched several forums and websites, not finding anything on this. I know the rods have to stay stock length, so could some of the Super Stock engine/racers help me with this info. (Can the pistons compression height be shortened.) I have had the heads, intake, crank, and Jesel rockers with belt drive for this build sitting here for a good 10 yrs now and what to restart the build. Heads and intake were done by the late Dave Layer, things may have improved since then. Thanks for any info you can provide, would like to order the block, which the heads and intake need the block decked to fit the top end.
Regards,
William
boydw2000 is offline   Reply With Quote
Old 02-03-2024, 12:54 PM   #2
Default Re: Super Stock Piston Compression Heights
Regards,
William
Stock compression height is not required in Stock or Super Stock.
Be aware that some good tech inspectors will look down upon radical milling of components (blocks and heads) and how legal it is.
Old 02-03-2024, 02:50 PM   #3
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
There is a minimum CH listed for Stock replacement pistons but not for SS that I can find.
Paul Precht is online now   Reply With Quote
Old 02-03-2024, 10:36 PM   #4
boydw2000
Thanks guys, appreciate the replies.
Old 02-03-2024, 10:47 PM   #5
Dyno
Dyno's Avatar
Liked 687 Times in 205 Posts
As long as your deck clearance is correct and head gasket thickness measures correct, the pin height does not matter in SS. If your deck height is short , you can make up the difference with a thicker head gasket or the other way around. Make sure your CC"s are correct for the chamber volume and your runner volumes are equal or less than listed. Watch either dome height or dish volumes.
