Old 01-11-2024, 08:33 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Accusump - pros & cons
Mcfly, it’s now the year 2024 and the vast majority of class racers and bracket racers have their engines built by professionals so you either ain’t got the coin or your arrogance eclipses your ego, seeking validation from a few old men like yourself wanting a merit badge for assembling your engines, setting a few clearances, assembling a few parts and torquing a few bolts who call that “building” their engines.
Old 01-11-2024, 01:27 PM   #2
Rory McNeil
Well, at least I won`t need to ship my engine back to the "Big Name Profesional" if a spark plug wire falls off ! Or fly them if when the valves need adjusting.
NHRA 6390 STK
M/S 85 Mustang
Old 01-11-2024, 01:29 PM   #3
1320racer
1320racer's Avatar
Your attempt at humor is as bad as your attempt at spelling Mcfly
Old 01-11-2024, 05:43 PM   #4
L.Fite
Liked 502 Times in 245 Posts
never mind...
L.Fite is offline   Reply With Quote
Old 01-11-2024, 07:36 PM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
When adding an accumulator. Are you guys running the same amount of oil in the pan?
Old 01-11-2024, 08:28 PM   #6
SBillinson
Liked 183 Times in 48 Posts
I add two quarts for the accumulator.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 01-11-2024, 10:14 PM   #7
J.R. Haddad
Liked 1,471 Times in 308 Posts
Robin, as the op of this post, I would like to thank you for your very
insightful posts. That is certainly the type of information that I, and I'm
sure other readers were looking for. You were very helpful with your
information, just as you have been when I've called you.
Thanks Again,
J.R.
J.R. Haddad is offline   Reply With Quote
Old 01-12-2024, 06:42 AM   #8
1320racer
1320racer's Avatar
Thanks Again,
J.R.
Really, tell us what he said pro or con about using an accusump. You can't because he said NOTHING! Further he states and admits
Originally Posted by Robin Lawrence View Post
I have no opinion. I've not used one yet.
So Robin like me, hasn’t used an accusump because he doesn’t have low oil pressure when decelerating and/or braking which is due to poor oil control.
That said, it’s obvious, you don't want advice, don't want opinion, what you want is confirmation of what you have already decided to do. Why? It’s your engine, your $ and no one really cares what you do!
Old 01-12-2024, 11:12 AM   #9
J.R. Haddad
Ed, Ed, Ed. You are replying far too early in the morning. Walk the dog,
have a coffee, relax, it's only January, we don't want you to burn out
early. We need this level of entertainment until early spring, then we
can cut you loose.
You keep mentioning my oil control problem. Guess what?? Don't have
one. I've run my car with less oil than I like to, never a problem. Oil
pressure gauge never makes a move, same when I download my data.
You asked me at the beginning of this thread, what band aid I was looking
for, and I told you then I was just being pro active. You just chose not to
believe me, so you continue the drama you desire. In the meantime, some
really good people have given their experiences, thoughts and ideas. I have
enjoyed the thread so far. I hope others have as well.
Regards,
J.R.
Old 01-24-2024, 07:24 PM   #10
MarcoFD1
Ok here is a question how do you get oil into the accusump and how much air do i add to I. I have the moroso model
MarcoFD1 is offline   Reply With Quote
