#41 |
Liked 460 Times in 59 Posts
#42 | |
Liked 269 Times in 99 Posts
LOL!! ![]()
#43 |
Liked 299 Times in 48 Posts
#44 |
Liked 183 Times in 48 Posts
A wise man once said: An ounce of prevention is worth a pound of cure.
There is no downside to an accusump. On my car, I have a single stage external pump plumbed to a good pan with a sump that's almost completely covered and baffled. Oil pressure drops at the stripe if I don't immediately kill the engine. Apart from an accusump, I "waste" my money on coated bearings and racing oil. On an expensive, professionally-built racing engine that turns 10,400 rpm pass after pass, I "foolishly" spend a few hundred more on parts that any professional builder would consider a good idea.
SS/BS 1921 |
#45 |
Liked 759 Times in 379 Posts
There is, it doesn’t fix the root cause of low oil pressure which is due poor oil control. Hence it’s a band aid and should call into question one’s choice of engine builders IF said low oil pressure on deceleration and/or braking is a real concern.
That said, you and anyone else that choses to do so, need not justify your decision about your program to anyone and can “foolishly” spend your $ on and installing an accusump and it affects no one here but this thread isn’t about you and isn’t about an engine that turns 10,400rpm either! Last, I have yet to have any professional engine builder tell me, suggest to me, that I need to use an accusump with their engine, Last edited by 1320racer; 01-09-2024 at 01:33 PM. |
#46 |
Suddenly, I'm reminded of another saying.
“Never argue with a fool. They'll drag you down to their level and beat you with experience.”
SS/BS 1921 |
#47 |
Says a fool that thinks he knows
#48 | |
Liked 71 Times in 38 Posts
#49 |
Mr. Reher hasn’t built an engine in years and I have no need for his services as my engines are built by 2 of the best in sportsman drag racing engines.
#50 |
Liked 346 Times in 126 Posts
Logical fallacy, even if he has not built any in years does not discount his expertise. and who are these "mystery" builders?
