#31 | |
Liked 346 Times in 126 Posts
#32 |
Liked 759 Times in 379 Posts
Of course you do and I do because I too have an opinion just as anyone else that has replied and how does an accusump affect you?
![]() Last edited by 1320racer; 01-08-2024 at 04:04 PM. |
#33 |
#34 |
Again, the pros and cons of using an accusump is an Engine conversation and not exclusive to engines being used in stock and super stock cars.
#35 |
#36 |
WRONG you don’t care and speak only for yourself and I don’t care about your opinion!
#37 |
#38 |
Liked 460 Times in 59 Posts
David Reher of Reher Morrison:
"One of the best investments a sportsman racer can make for a wet-sump engine is an oil accumulator such as an “Accusump.” An oil accumulator is a sealed cylinder that contains a floating piston. Pressurized air on one side of the piston forces a reserve supply of oil into the engine if the flow from the internal oil pump is momentarily interrupted. An accumulator works automatically and requires virtually no maintenance except regular cleaning. Unfortunately, accumulators are seldom seen in drag racing. That’s a pity, because they really work." https://rehermorrison.com/tech-talk-...-engine-alive/ |
#39 |
Liked 920 Times in 259 Posts
Accusumps work well for their intended use. Cranking an engine before starting is still running parts together that may or may not be dry from sitting.
Cams, lifter bores, bearings and rocker gear with high spring pressures don't give a damn what class they are being used in. Band aid or not, an Accusump can be useful with shallow, front sump, flat bottom pans and/or high G forces. Likewise, full oil galleys and oil where it needs to be before the engine is cranked does make a difference. Don't like 'em, don't use 'em. Last edited by CMcAllister; 01-09-2024 at 12:02 AM. |
#40 | |
Nuff said |
