Liked 72 Times in 36 Posts
How come Brake Fluid in new cars and trucks have to be changed nowadays and when I bought new cars and trucks in the 60's 70's 80's 90's. i don't remember that being necessary. Does all the brake fluid today need to be changed out including in the race cars?
Thank You Kenney Kelley |
Liked 759 Times in 379 Posts
Brake fluid always had to be, should have been changed and it’s the root cause of “frozen” calipers.
That said changing race car brake fluid is even more important especially if you don’t use DOT5 silicone which is the only fluid that does not overheat and burn and the only fluid I use in my race cars which I change every season. DOT3, 4 and 4.5 pour clear and drain looking like black sludge from excessive heat. Last edited by 1320racer; 01-08-2024 at 02:10 PM. |
Liked 888 Times in 239 Posts
Brake fluid change has been recommended for years by manufacturers . When I started as a technician 50 plus years ago ,we used to flush the systems with denatured alcohol.
Brake fluid is hydroscopic ,it absorbs moisture from the atmosphere and becomes both a rust agent and corrosive to the system .constant heat also degrades it ,becoming black and sludgy With the advent of antilock brake systems regular servicing of the fluid became more critical as the antilock system employs several close tolerance high speed actuator valves that are easily damaged by contaminated fluid . As it applies to our race cars ,brake fluid should be flushed and replaced every season , preferably at the end of the season before storage . DOT 3 or 4regular fluid is fine for a street car ,but race cars that experience extremely high temperatures should be using race specific fluids that have a much higher wet boiling point such as Wilwood Hi Temp 570 or EXP 600. Castrol ,VP ,Motul and others all make high performance fluids with higher wet boiling points. The higher boiling point fluids do not sludge up nearly as much as street fluids.
Tom, I have tried Wilwood’s Hi Temp 570 and it too overheated, burnt and was black sludge, just as bad as DOT3, 4 and 4.5. Again the only fluid that I have used that doesn’t burn, overheat, cook, turn black is DOT5
#5 | |
The silicone fluid has it's pluses for sure ,but silicone has 3 times more compression than regular fluid . Not something that a foot brake racer might feel comfortable with. The 570 and 600 works pretty well on Stock Super Stock type cars . ...The Motul fluid in my opinion is even better than the Wilwood fluid . I used to do SCCA inspections and maintenance on several road race Corvettes .Fluid flush and change is required before EVERY event....All fluids brands show some degradation . The Motul fluid really was superior to most of the others ,only Wilwood 600 was as good . We're talking cars that get the brakes so hot that the caliper piston boots melt or burn up and the rotors dont last more than 2 races!
#6 | |
Liked 10 Times in 3 Posts
Have you tried Castrol SRF? Its wet boiling point (which is more applicable to how most people care for their brake fluid) is higher than all the other high temp offerings out there. I have used it with great success in road racing compared to Motul 660 which is a nice fluid in itself, but if you aren't flushing it very often it has issues like all the rest. I value wet boiling point much more than the dry points they all advertise, since unlike the road racing stuff, I do not plan on flushing the fluid weekly |
I have not, but I do flush my system before the start of every season and I swap out the calipers every other season, sending them back to Mark Williams for rebuilding.
#8 | |
Liked 133 Times in 76 Posts
#9 | |
Liked 228 Times in 117 Posts
I'm in the process of changing my fluid in the race car now as part of its annual maintenance. I need to pay a little more attention to my daily drivers. |
