Old 12-06-2023, 04:38 PM   #11
65signet
Liked 48 Times in 22 Posts
Default Re: 273 Mopar heads, stock or Eddy?
I run the 675 318 heads on my 273, they work good, the 302 heads are prone to cracking.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 12-16-2023, 08:00 AM   #12
Rick J
Liked 73 Times in 37 Posts
Are the 302 heads hard to find without cracks? Or do they crack after prepped and raced?
Rick J is offline   Reply With Quote
Old 12-16-2023, 11:53 PM   #13
GTX JOHN
Liked 2,486 Times in 697 Posts
A lot of the 302 I find are cracked between Intake and
Exhaust Seats OR Exhaust seat to Spart Plug hole.
Usually, they do not cause a leak but I am reluctant to
spend a lot of money on them if visually cracked.
I believe they overheated in street use before i found them.
I have never cracked any small block Mopar heads that were in
place on my races cars and were not cracked before that.
John Irving
741 Stock
741 Super Stock
Old 12-17-2023, 07:51 PM   #14
Rick J
Thanks
Old 12-20-2023, 05:46 PM   #15
66formulas
66formulas's Avatar
Liked 5 Times in 1 Post
Originally Posted by Paul Wong View Post
If you can find the edelbrock heads they would be fine. I have been looking and not seen a set in over 2 years. The bill to make them work might knock you off your chair. I have a set it and nothing even comes close to working.
The iron heads made great power. No need to spend prohibitive money trying to make the aluminum heads work.
What is the catalog number for the Eddy heads. The one listed on nhraracer are big valve heads. Do you have to put smaller seats in the head?
66formulas is offline   Reply With Quote
Old 12-22-2023, 09:09 AM   #16
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Yes you have to change seats and the make the runner the same size as OE head you're replacing. Next question becomes how to do that legally!
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 12-22-2023, 12:43 PM   #17
Paul Wong
Liked 419 Times in 85 Posts
Yes. Get out the wallet. I have a set and the work it takes is not rational. Look at the CC numbers and get to thinking about that for a minute.
Paul Wong is offline   Reply With Quote
