Liked 83 Times in 24 Posts
Seems to be a Mopar trans to Chevrolet bell housing
Has not been used Want to list it for sale once i have more info on it ![]() ![]() Thanks Dom |
Liked 170 Times in 55 Posts
Is the bellhousing a cast part of the case, or does it bolt on? Hard to tell from your pictures.
Div 3 Sales, Service and Tech for many manufacturers |
Liked 24 Times in 11 Posts
That is a 904 Chrysler built for AMC . It was used in AMC cars in early 80's in Sprite and others with the GMC 4 cyl Iron Duke motors . They had a lower first and second gearset - 2.72 and 1.54 instead of the 2.45 1.45 standard gears. As far as I know, everything is standard 904 internals. AMC also used the 904 with AMC bolt pattern behind the 6 cyl 258 motor. That's what I use behind the 4.0 in my Comanche. That trans will probably need the MOPAR converter.
#5 | |
Liked 5,153 Times in 1,967 Posts
In 1980, the Iron Duke was redesigned with the new GM FWD bell pattern. The one pictured is a std Chevy RWD pattern.
Liked 172 Times in 81 Posts
AMC 904 postal van transmission. I believe they were all 904's, not the 998/999 V8 version which had a larger front servo and 4 pinion planetaries. Easy to tell a V8 unit from the outside, they have 2 ribs on top of the rear servo.
Jim Mantle U/V/SA 6632 |
Is anyone familiar with the Dynamic that built this trans.?
Are they still in business? Thanks Dom |
Liked 49 Times in 22 Posts
Steven Barnes Stock 704 N/SA |
Liked 398 Times in 153 Posts
Dynamic transmissions is in Connecticut, used to be partners with Frank Lupo's Dynamic Converter, but I don't recall what year they split up.
Phil Molski PMR Performance S/C 1623 |
#10 | |
Liked 805 Times in 341 Posts
From Facebook: 104-5 Enterprise Dr # 5, North Branford, CT (203) 315-0138 dynamicracemail@aol.com |
