12-03-2023, 09:09 PM | #1 |
Gear & Tire question
I have an 70 nova bracket car, looks like it was built around the 90s or so. The car is on 33x10.5 Hoosier slicks, 5:13s in the rear. I’m hitting trap around 63-6500. How would going down to 29s affect my car? Car is running around 7.4-7.5.
Car specs: 12 bolt Strange axles 5.13 gears Th400 reverse manual valvebody no brake 60 over 350 Dome top pistons H beam rods Solid lift cam Holley alum heads Quick fuel 750 Last edited by Meaney124; 12-03-2023 at 09:27 PM. |
12-04-2023, 07:46 AM | #2 |
Liked 424 Times in 204 Posts
Re: Gear & Tire question
1/8th mile?
cam specs? converter size, flash rpm and fall back rpm stock suspension? footbrake? Last edited by 1320racer; 12-04-2023 at 07:48 AM. |
12-04-2023, 08:02 PM | #3 |
@1320racer 1/8th mile unsure of cam specs haven’t torn apart to get numbers or anything, ladder bar, and footbrake is about all the info I can give you lol
12-04-2023, 08:05 PM | #4 |
12-04-2023, 08:11 PM | #5 |
Liked 1,678 Times in 533 Posts
Summit has a gear ratio calculator on their site. Plug in the info it should get you close
KEITH MAYERS 2 X somebody many X nobody |
12-05-2023, 10:54 PM | #6 |
Liked 178 Times in 63 Posts
So, you must be trapping about 118mph at 6500?
33 to 29 inch tire jumps you from 6475rpm to 7367rpm. (approx) http://wallaceracing.com/calc-gear-tire-rpm-mph.php |
12-06-2023, 07:45 AM | #7 | |
Don’t know if he mentioned it is 1/8 mile. Lol. I do believe some of these calculators have 1/8 mile data
