#1 | |
Liked 1,912 Times in 429 Posts
Really? And you have how many class wins with your big block Stock Eliminator engines? Because I have more than 1-2. Oh, and I have a 9500 RPM+ 396-375 Super Stock engine as well. Maybe YOU can't make a flat tappet Stock Eliminator engine run. That does not mean the rest of us can't. There are a ton of VERY fast big block Chevy stockers out there running flat tappet cams and having zero problems. Maybe you should ask yourself why YOU can't.
Alan Roehrich 212A G/S |
#2 | |
Liked 187 Times in 58 Posts
John Ancona 717 STK / SS |
#3 | |
But you're saying that roller lifters and roller cams are necessary for Stock Eliminator.. Maybe you should help Terry fix his problems. ![]() What I wrote is factually correct. Converting to roller cams and lifters will require entirely new lobe designs. Oh, and you can then use even stronger valve springs, turn more RPM, break something else, and cry for another rule change.
#4 | |
#5 | |
You know, that's actually decent advice. You should take it.
Liked 735 Times in 386 Posts
Ignoring pushrod angle against the lifter. A flat lifter / cam really produces no side loading.
Again ignoring pushrod angle against the lifter. A roller lifter / cam will produce side loading. Look at pressure angle. While a roller lifter doesn't the max velocity limit of a flat lifter, at does have other limits. Again look at pressure angle. Stan |
#7 | |
Yep. And they haven't gotten into the differences in lifter diameter, lifter wheel diameter, or what all of that will do to the rest of the valvetrain, like the rocker arms, rocker studs, rocker stud bosses...... As usual, a lot of people THINK they know. Then they'll be stunned at the can of worms they opened. They fail to understand, they do not want that genie out of the bottle, because it will NEVER go back in.
Liked 508 Times in 92 Posts
Maybe taking a couple of steps backwards would help Stock more than of going with parts that would cost more money and people with deeper pockets having advantages. Stock as stock, hydraulic lifters back where they belong in the engines that came with them from the factory. Have a valve spring pressure rule to where an engine family can run +30 lbs from design.
With the changes, there wouldn't be a big need of the AHFS, cars would fall back to the performance levels that were expected. If you haven't noticed, but the age of the racers isn't getting any lower. New blood can't afford a Stock prepared car because of rules that don't make sense about a stock car. This is just my opinion, I don't need hate replies. Casey Miles 248H Stock |
#9 | |
Liked 498 Times in 244 Posts
Feel free to PM... I'm here to learn. |
Is this really a spring pressure problem, or a material quality issue?
I seem to hear others having similar issues with street/strip type cam profiles. Wondering if it is not a more widespread problem than aggressive profile / high spring pressure that magnifies the problem? |
