Old 07-28-2023, 05:12 AM   #1
barnym17
Default Re: Manual steering box for a body drag racing – 24 to 1 or
There should also be an adjustment on the end of the steering box suggest consulting service manual for specs.
barnym17 is offline   Reply With Quote
Old 07-28-2023, 09:05 AM   #2
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I have a 70 Chevelle. 10.0 index car.
I put tall front top ball joints in. Helped bump steer and camber. I have limited travel with bolt Thru upper arm where it hits the bump stop on upper chassis. Otherwise you get excessive travel with the upper arm more parallel with the ground at ride height. Also check your rag joint. If you have one. Some good advice here Thru this thread. Make sure everything is right and articulates smooth. Remove shocks and check. Then check with shocks in place. Hopefully wherever you are is a good race shop that understand our cars. My guy retired so I’m outta luck locally that I know of on Long Island.
chris ok is offline   Reply With Quote
Old 07-30-2023, 05:35 PM   #3
CraigG
Liked 8 Times in 7 Posts
Hey Everybody,
Gentlemen, thank you for all your assistance. My current plan is to put on the Global West steering knuckles kit for mitigating bump steer, getting a new 24 to 1 Saginaw manual steering box and returning to the four wheel alignment for re-check and especially rechecking toe in.
Thanks again, Craig
CraigG is offline   Reply With Quote
