Old 06-13-2023, 11:23 PM   #15
FED 387
Liked 333 Times in 180 Posts
Default Re: Front tire life?
buy a new set every spring run them the entire season leave them on over the off season so you can roll the car around and put the new tires on in the spring-- part of the cost of racing--if you are not doing 130 MPH brake jams they should last a while like anything else you abuse them they will wear out FAST--FED 387
